emerie zaiya
New member
- Joined
- Oct 10, 2025
- Messages
- 2
Just joined the forum because I’ve been stuck on a problem with my Bowrider and figured someone here might have dealt with it.
Last weekend, I took the boat out for the first time this season—got it winterized last fall, so I thought it’d be smooth. But when I turned on the stereo to play music for the kids, it just cut out after 5 minutes. Now it won’t turn on at all, even if I reset the fuse (checked the one by the stereo and the main panel, both are good).
I tried a few simple things: disconnected the stereo’s power wire and reconnected it, made sure the ground wire wasn’t loose (it’s bolted to the frame like it should be), and even tested the battery with a meter—reads 12.6V, so it’s not dead. The rest of the electronics work fine—GPS, lights, bilge pump—so it’s just the stereo.
Is this a common issue with these older Starcraft stereos? Mine’s the original Kenwood one that came with the boat. Should I just replace the stereo, or is there a trick to fix it? Also, if anyone has a recommendation for a replacement that fits the dash opening (don’t wanna cut anything!) and works well on boats, that’d be awesome.
Thanks in advance—hoping to get this fixed before our next family trip!
