m33rwand3r
New member
- Joined
- Aug 18, 2025
- Messages
- 2
I'm finally getting started on restoring my dad's 1968 StarChief! It's been sitting since the pandemic, and I'm mostly concerned about the hull's integrity. I was worried about chine cracking, but it still looks solid. I do need to beat a portion of the spray rail back into shape, but that's a small task. The biggest problem is the leak he complained about, which he "fixed" by dumping a tube of silicone on the transom seams. I'm thinking of using Gluvit to seal it all up. I figure I'd also add some extra aluminum angle to the spots most likely to crack. I'm going with closed-end pop rivets since I'm doing all this myself, aluminum for new locations and stainless steel if I have to replace any existing rivets. The plan is to shorten the splash well, add some jump seats, and open up the bow to make it more of a modern fishing rig. It looks like the old 75hp Suzuki still runs strong, but I'm hoping to play with prop selection and trim to get a little more speed out of it once the hull is stiffened up.
I'm interested to get feedback about my plan. Is it doable? Too ambitious? I'm also open to other ideas to experience this almost like brand new again. Looking forward to getting your insights!
